![]() Join Date: Mar 2009
inline 6 intake/exhaust bolts
I bought a 67 with an inline 6 and it has the wrong bolts on the intake/exhaust.the intake and the exhaust manifold leak. I can't find anywhere to buy new or used. any help would be greatly appreciated. Bolts with the weird washer things is what I'm after.
![]() Join Date: Dec 1999
Re: inline 6 intake/exhaust bolts
Become a supporting member - here - http://67-72chevytrucks.com/vboard/payments.php
Post a WTB(Want to buy) in the parts board. You can order standard studs and bolts once you have the clamps. Here is a thread with some pictures. http://67-72chevytrucks.com/vboard/s...d.php?t=454785 |
Scrapper 1
Not sure if i saved the ones off my old 250 Not sure witch one i had in year
![]() Join Date: Nov 2006
after you find the fasteners it wont cure the manifolds leaking. you have to take both manifolds to a machine shop then have the center where they bolt together ground flat, install a new gasket then surface both manifolds bolted together where it meets the head. tighten it down from the center outwards. then retorque several times after getting it hot.
I BELIEVE IN JOHN 3:16 |
