Old 04-19-2018, 11:50 PM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
1996 C1500 lift question
I bought a 96 C1500 extended cab. It has a 2 inch coil spring lift and a 4 inch spindle lift. It has the factory stamped upper control arms. And they are extended all the way out, and face down close to the bump stops. Does anyone happen to know a place I can order maybe tube extended control arms? When the suspension droops down the tire goes way negative camber and puts a bad angle on the ball joints. Thanks in advance!
SoCalSlaughter is offline   Reply With Quote
control arms, lift, lifted
