05-03-2018, 03:30 PM | #1 |
Plastic in oil what to do.
I pulled my valve covers the other day and notice chunks of plastic sitting on the heads. I read its usually the timing gear that failed. The motor was running fine but is it possible to just clean out the motor and replace the timing gears and chain and be OK or should I be more concerned there is more damage. I'm not to happy but I'm hoping everything is alright.. Thanks
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
05-03-2018, 04:26 PM | #2 |
Re: Plastic in oil what to do.
Are you sure it's not failed valve seal umbrella pieces? I'm trying to picture how large chunks of timing gear would get up there without going through the pump and getting filtered out. Maybe they could bounce and work their way backwards through the drainback passages between the valve covers and timing chain area and bounce up into the valve cover area? I don't know. I don't want to doubt your observation; I'm just brainstorming to see if it's something else. Something easier.
What color are the plastic parts? Valve stem seal umbrellas are usually dark and nylon timing teeth are usually off white. You might be luckier than you think. If it's not the timing chain then you could get by with just a cleanup and new seals and gaskets for the heads.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
05-03-2018, 04:29 PM | #3 |
Active Member
Did you happen to take pic of the pieces? What color were they?
Personally I don't see how they got by the oil filter. Might be something else like broken pcv.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-03-2018, 05:02 PM | #4 |
Valve seals. I would clean it out and keep driving until the puffs of smoke become too much of an annoyance to you.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-03-2018, 07:04 PM | #5 |
It is chunks of black plastic smaller pieces I’ll post a picture.
05-03-2018, 07:31 PM | #6 |
Post Whore
sounds like valve seals..thats about the only thing that would be under the valve covers...does it smoke a little when you first crank it cold?
05-03-2018, 07:38 PM | #7 |
After you guys mentioned it I am certain that what it is. No pics at the moment but what I see online that’s it. It’s hard to tell the exhaust dumps under the truck but I’ll look next start after I clean it out.
05-03-2018, 07:38 PM | #8 | |
Active Member
Also, about 4-5 years ago I removed the valve covers on a 1977 Corvette engine I had bought. I found small black chunks of plastic that turned out to be totally dried out and brittle valve stem seals (as mentioned above). I used compressed air to remove the valve springs and replace the stem seals.
05-04-2018, 11:54 AM | #9 |
Definitely agree it's valve stem seals. I recently replaced the worn out timing gears on my '68 so I know all too well what that looks like. I dropped the pan to replace a leaky rear main seal and was greeted with a pan full of tiny plastic pieces. The oil pump was also jam packed with bits. I had no clue what to think of this until I did some searching here on the forum and realized my truck had plastic timing gears!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-04-2018, 01:34 PM | #10 |
Wow that is bad! Yeah the chunks in mine look different you can tell that is from the timing gear on yours.
