Old 05-04-2018, 09:34 PM   #1
NJKelly
Is this hatch worth saving?
This was part of a group purchase yesterday and. Maybe pull hardware/glass and scrap the fiberglass.
NJKelly is offline   Reply With Quote
Old 05-04-2018, 10:35 PM   #2
Tuff Gong
Tuff Gong's Avatar
Re: Is this hatch worth saving?
Definitely pull hardware.
Tuff Gong is offline   Reply With Quote
Old 05-04-2018, 11:04 PM   #3
NJKelly
Thanks for the reply.
Old 05-04-2018, 11:14 PM   #4
extd56
extd56's Avatar
I have seen worse fixed
extd56 is offline   Reply With Quote
Old 05-04-2018, 11:53 PM   #5
NJKelly
I was thinking something could be done to save it. New to this so not sure when to draw the line.
Old 05-05-2018, 11:02 AM   #6
stangtjk
Mine was in similar shape and i separated the two halves and repaired it from the inside. It's not hard to fix but if you don't need it it's probably not worth your effort.
stangtjk is offline   Reply With Quote
Old 05-05-2018, 11:15 AM   #7
NJKelly
How did you separate it? Is there a thread on here you followed.
Old 05-05-2018, 11:26 AM   #8
stangtjk
Didn't follow any thread. Just went out and did it. Heat gun and a 2" metal putty knife is what I used to separate it. Just heat up the seam and scrape out the adhesive. It's not a quick process. I didn't time it but if memory serves me right it took a couple hours.
Old 05-05-2018, 11:56 AM   #9
NJKelly
The hatch on my top is also cracked, but not as bad. I think I'll learn on the one in this thread. Then fix the other as well. When you glued it back together did you use a specific adhesive?
Old 05-05-2018, 12:26 PM   #10
stangtjk
I don't remember the exact adhesive I used. It was a general construction adhesive specified for fiberglass. I had to fix a lot on my top as well, actually ended up fiberglassing the whole top of it to fix the sags (double wall top). Didn't take many pictures of the process.
Old 05-05-2018, 12:28 PM   #11
NJKelly
Looks awesome, good work. Thanks.
Old 05-06-2018, 02:28 PM   #12
cleszkie
cleszkie's Avatar
Fixing from the inside is the only way to restore the structural integrity of the hatch.
Before you toss it in the trash, keep one thing in mind. In a couple of years when these hatches are even rarer and the value of a Blazer in general increases, a hatch in this condition will be sought after. One man's trash is another man's treasure.
cleszkie is offline   Reply With Quote
Old 05-08-2018, 09:36 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Agree.
This Blazer has a $57k asking price - here's the "hatch" you get for that...
Old 05-09-2018, 02:17 PM   #14
mister.freeze
mister.freeze's Avatar
any more pictures of that hatch? I plan on doing some sort of all glass hatch this summer and need ideas/guidance.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 05-09-2018, 02:50 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It's listed on ebay right now. I can't recall if any additional hatch pics but maybe the seller can send some detailed ones.
Old 05-09-2018, 03:27 PM   #16
mister.freeze
Specific link?
Old 05-09-2018, 07:54 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
sorry you'll have to search for yourself
Old 05-10-2018, 01:03 PM   #18
stangtjk
The full glass hatch is kinda cool but it just doesn't look right with the small side windows...... Proportions are just off..... If you modified the top so the side glass took up almost the whole side starting from the bed rail it might look like it was meant to be. Kinda like the defender 90s customized by himalaya.
Old 05-10-2018, 04:06 PM   #19
maldo
maldo's Avatar
If you decide to part out I would like to buy the hatch handle .
maldo is offline   Reply With Quote
