Need some advice on 1" drop coils..and Belltech spindles
My 83 has 2.5" western spindles with one full coil cut, its about a 4.5-5" drop over stock. I'm fairly happy with the ride quality, running 15x8 rallys with 225/70 tires.
I have a 87 GMC, I'm fixing to drop , I have 3" Belltech spindles ordered. I want the front to be no lower than about 4" ... Anybody have any suggestions on 1" drop coils that you have actually used used and gotten a true 1" drop out of? And will the Belltech give me a true 3" drop? I am tempted just to do the spindles, but am afraid it may be a little high in the front with a flip in the rear. I'm not against cutting the factory coils... but don't want to get more than 1" or so spring drop.
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
![]() Join Date: Dec 2006
Re: Need some advice on 1" drop coils..and Belltech spindles
Here's one I did with a 3" spindle and a new set of big block springs with 1 round removed. It was about a 4" drop in the front and 5" in the rear with a flip kit.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
Here's a pic of the same setup on another truck I had with a 4/5 drop.
So you recommend the new big block springs cut over drop coils?
I've never used a 1" drop spring but I have used 2-3" springs and don't care for the soft ride. I prefer my trucks a little stiffer with less "float". You get an increased spring rate when you cut factory springs.
I ordered some big block moog springs! thanks
Posted via Mobile Device |
Combine that with some KYB shocks and I think you'll be happy with the ride.
![]() Join Date: Nov 2008
This is how my sons truck looks .. Belltech 3 inch drop spindles and Belltech 1 inch drop coils . Rear axle flip kit .. Rides nice , very happy with it ..
I used your exact setup, with the big block coils cut and KYBs, the ride is great! a lot better than my 83 with the "factory" coils cut! Thanks for the advice!
Glad to help. That's a great combo for a mild drop and good ride. Post some pics.
Here it is!
Looks good sir. I would expect the front end to settle a 1/4-1/2" and that will be perfect. I'm really starting to dig a stepper, I may have to build one.
#13 |
ULTRAHD4ME, thanks for sharing your recipe. Beautiful trucks. RWJJR, your stepper looks good. Thanks for the feedback on the set up. I got belltech spindles to put on, but mine's a long bed so I'm not going to go as low. To my eye, the long beds need to keep a little elevation to keep the proportions right to the wheels. I like how yours came out.
#14 |
part # for the big block springs used?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#15 |
Hey, Just wondering what wheel and tire size on the first two trucks? They look good!
#16 |
I just ordered a set of Moog 6454 springs. Hope those are the right ones. What's a good tire combo to run with the 4/6 drop? I have a pair of 235/60r15 to put on the front. I would like to run a 275 on the back, but I don't have wide enough wheels.
