05-10-2018, 10:43 AM | #1 |
1970 Daily Driver
What is the green with black stripe wire under the hood.
What is the green with black stripe wire under the hood? Had to redo the heads On my 1987 TBI 454. Have a green wire with black stripe that I’m not sure where it goes. Any help would be greatly appreciated.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
05-10-2018, 12:51 PM | #2 |
Re: What is the green with black stripe wire under the hood.
Single green wire on my truck is the tach output.
05-10-2018, 12:55 PM | #3 |
Idiot lights, or gauges? Engine Size?
I have idiot lights on my 86' and a 350 v8. One of the green wires under my hood connects to the temperature sending unit/switch located on the driver's side between my exhaust manifolds in the front. It has a black adapter on the end that slides onto the temperature sending unit (which looks like the head of a nail). |
05-10-2018, 09:30 PM | #4 |
Green wires in that location are usually one of the following:
Temp gauge or idiot light to sender AC compressor clutch Idle comp solenoid Electric choke The last two probably don't apply to a TBI. I think some AC compressors had the high pressure cut off switch in or on the compressor instead of over by the AC box. |
05-10-2018, 11:44 PM | #5 |
Moderator
HPCO, if present is an owner/builder add on.
LPCO is on the accumulator. Solid green wires. THe above run to the AC compressor. The only GREEN/Black under the hood in 1987 is one of four wires to the IAC. Specifically Circuit 444 from the ECU to IAC stepper coil B... Are you sure it has a black tracer stripe and it's not just filth?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-11-2018, 05:08 AM | #6 |
Looks like the Temp Sensor wire. Mine was laying lose in the engine room, because the previous owner had put an aftermarket temp unit in. I put a heat resident loom on it, since the temp sensor is right there by the headers. The original plug was melted, so when I put a new one on, I thought I would try and help protect it from the heat.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
05-11-2018, 09:59 AM | #7 | |
Moderator
I do agree that's what it looks like... but if there's really a black tracer stripe then that's not what it is. Would it work better to run the temp wire over the top of the valve cover and back along the intake?
