Old 05-26-2018, 01:11 AM   #1
LT7A
Hood insulation: Why? Do you keep it or don't you?
I posted this over in SquareLand but I figured I would see if I could get input from people that hang out in other parts of the forum since the topic applies to more than squarebodies.
I've had some vehicles with hood insulation and some without. From a high performance mindset, I can't see how it would help. Unless you live way up north in Coldlandia or Coldaska and have a hard time maintaining operating temperature, I don't see how there's a benefit except at initial startup/warmup. I can more easily make a case that it's there just to suppress sound. We all know that NVH is really important to the manufacturers. I would imagine that quiet seems smooth, and smooth + quiet probably help sell vehicles on test drives. Once up to operating temperature, it seems that any insulation would have a negative effect on performance. There is a lot of air going over the top of the hood that could draw heat out of the engine compartment. The closest thing to the hood is typically where the air and fuel are being drawn in. Any drop in temperature in that area sure seems like it would be a performance gain however minimal.
I'm considering pulling the hood insulation out of all of my rigs. I don't mind hearing the motor when it's doing its job. And generally speaking, if it's not revving up, then I don't think it's going to transmit much noise through the hood through the windshield and into the cabin. And I don't mind startling innocent bystanders and woodland creatures when I drive by. What do you guys think: Keep it, add it, toss it?
Old 05-26-2018, 06:48 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Hood insulation: Why? Do you keep it or don't you?
my 81 came with the insulation...but it looked crappy...so I replaced it... more for visual than anything
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-26-2018, 08:20 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Some say it's to keep the paint from fading due to engine heat others for noise. Because of the thinner metal used it's probably for both reasons but I see more vehicles with hood insulation that have faded hood paint than I did when they didn't have insulation.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-26-2018, 04:56 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
All about engine noise!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-02-2018, 03:06 AM   #5
toolboxchev
I ripped that moisture trapping crap outta there. Now I can watch the tune on the engine just by driving down the road!
toolboxchev is offline   Reply With Quote
Old 06-06-2018, 12:05 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Mine didn't have any from the factory (1972), and I ain't adding any...
Plus... I happen to like engine noise.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
bystanders, heat, insulation, performance
