06-03-2018, 10:57 PM | #1 |
Removing the Inner Rear Cab Panel on '53 5 Window?
I've got a '53 5 window that I'm working on, and I'd like to restore the inner rear cab panel, to sand and paint it.
1. Is this piece easy to remove once the seat is out and the gas tank is out? Does it even come out? 2. I assume there is some gap between the inner panel and the outer metal. When doing sound proofing and insulation, it is important to install it in this area as well? |
06-04-2018, 12:48 AM | #2 |
Re: Removing the Inner Rear Cab Panel on '53 5 Window?
It's welded in and NOT easy to remove by any means. I am working on one my self right now. The thing is I believe it was installed at the factory before the roof was installed. It's wider than the door jams are across, so I don't know how it could be removed in one piece.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-04-2018, 01:01 AM | #3 |
Thought so. Thanks for letting me know.
06-04-2018, 01:09 AM | #4 |
I was looking at a 5 window roof I have out back because someone on FB was wanting the window sections. They aren't easy to take apart right.
