Old 06-10-2018, 05:07 PM   #1
MARTINSR
MARTINSR's Avatar
How does the seat bolt into an AD?
It's been so long since I had a stock seat I don't remember. Does the seat simply bolt on top of the the mount that is welded into the cab? So if I were to section this mount lowering the top closer to the floor will the seat still simply bolt onto it?
In the second photo there are these two holes on each side of the rear of this seat mount. What are these holes for? I am thinking the gas tank straps?
Thanks for all your info given.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-10-2018, 08:38 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: How does the seat bolt into an AD?
maybe this'll help.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 06-10-2018, 09:01 PM   #3
Fred n' Ethel
Fred n' Ethel's Avatar
Just put mine (54) back together.
Put the slide rails in first, 2 bolts in each corner, using the slots in your picture.
Leave the bolts slightly loose, mount the seat onto the studs, then gently snug the 8 rail bolts up while checking that the seat slides for and aft freely, then torque em' down. You can get to them with a 1/4" drive ratchet and a deep socket.
Fred n' Ethel is offline   Reply With Quote
Old 06-10-2018, 10:55 PM   #4
MARTINSR
MARTINSR's Avatar
I'm sorry guys, what information I am after is how it looks, does it hang over much? I had forgotten about the side skirts. Outside of the side skirts does any of the seat hang over on the sides or front or inside?
I am looking to section this riser that is welded onto the floor. The cab is sectioned a few inches and the top is chopped three and a half so I need to lower the seat down and I need to know how much I can section this riser.
It looks like in those drawings that the seat track mounts to those two holes in my last photo. If that's the case I am out of luck.
Brian
1948 Chevy pickup
Old 06-11-2018, 10:09 AM   #5
jweb
jweb's Avatar
I just installed my seat and I don’t think sectioning the riser will work.
The seat tracks attach to the holes you show in the second photo and there’s no good way to drop those holes down.
You may think about just making a thinner cushion out of plywood and foam
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 06-11-2018, 10:15 AM   #6
MARTINSR
MARTINSR's Avatar
Okkkkkk crap, it looks like I have to have a whole different plan. I removed this riser from my old cab and bolted bucket seats on the floor but I really don't want to do that this time. I don't have a seat and wanted to get something done here before I get one.
I am thinking I could get the stock seat frame and not use the stock springs making pads with just foam like on a 27 T Roadster kinda thing.
Brian
1948 Chevy pickup
Old 06-11-2018, 12:52 PM   #7
jweb
jweb's Avatar
Brian
That’s exactly what I was thinking, just a thin foam cushion. I know someone on here recently showed how they built a cushion with plywood and foam and it turned out really nice. Unfortunately I can’t find it
Old 06-11-2018, 01:00 PM   #8
jweb
jweb's Avatar
Here's the build I was thinking of, starts at post# 648
http://67-72chevytrucks.com/vboard/s...383265&page=26
You would need to build a thinner cushion than he did, but the same idea.
Old 06-11-2018, 01:27 PM   #9
MARTINSR
MARTINSR's Avatar
yep, that is what I am thinking, thanks for the link. But I really need to lower this, I need to get the seat frame, I will be looking.
Brian
1948 Chevy pickup
