Old 06-11-2018, 10:08 AM   #1
81turbota
Best way to run return fuel line
As part of my engine swap I need a return fuel line. Is there a different pickup or an unused vent on my current tank I can use?
Thanks!
James
1971 Blazer 350/SM465/NP205
1966 Chevelle 468/TH400
2009 Corvette Z06 built LS7
81turbota is offline   Reply With Quote
Old 06-11-2018, 10:32 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Best way to run return fuel line
When I converted to fuel injection I ran the return line down the drivers rail.
There are no unused ports on the tank. I tried using the small vent line that runs beside the large fuel fill tube but that cause fuel filling issue's.
I ended up making a "T" that went inline on the fuel fill hose. Worked great.
It's just a piece of tubing with a barbed fitting screwed into it. I put JB weld around the barbed fitting just in case. It's never leaked...and it was cheap.
I think Jeg's sells something similar though.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-12-2018, 02:52 AM   #3
87Skier
87Skier's Avatar
The ideal way would be to modify the sending unit to have the return in it.
You could buy a new sender and have a welder tig a 5/16" pipe in or whatever size you want in place. There are also pass-through style fittings that you can piece together your system with.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is online now   Reply With Quote
Old 06-12-2018, 08:43 AM   #4
81turbota
Perfect, thanks for the ideas guys. I will be dropping the tank to clean it and replace the sender so I will likely go with the modification/welding route. BobbyK, the inline return is pretty slick. Sure saves a lot of work!
James
