Old 06-28-2018, 08:03 AM   #1
72farmer
Is it possible to install a bed stake fuel filler without messing up completed truck?
I am gonna get a top or side fill Boyd tank for my 71.I really hate to put the filler cap in the bed floor.I would love to get side fill and locate the filler somewhere else on left side.Can this be done with out causing a lot of problems on completed truck?
72farmer is offline   Reply With Quote
Old 06-28-2018, 08:32 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Is it possible to install a bed stake fuel filler without messing up completed tr
use a tail light filler
http://67-72chevytrucks.com/vboard/s...d.php?t=319408
Grumpy old man is offline   Reply With Quote
Old 06-28-2018, 10:40 AM   #3
custom10nut
custom10nut's Avatar
I like Grumpy's answer. The taillight filler can be done with minimal damage to the surrounding finish.
custom10nut is offline   Reply With Quote
Old 06-28-2018, 12:35 PM   #4
68blazer
68blazer's Avatar
that is a really old thread and if memory serves no one makes them or has a template. If i am wrong please point me in the right direction. i would like to do this to my project and the only advice someone gave from that thread (which grumpy only sent the first two pages) was to use cardboard to get the dimensions. i hope that helps you in your quest to have a really cool gas filler without doing damage. i do agree that the taillight filler is cooler than a stakeholder, just my 0.02
68blazer is offline   Reply With Quote
Old 07-01-2018, 02:16 PM   #5
Rufas
Rufas's Avatar
I used a fuel door off of a late 90's Chevy pickup and fuel pipe cover in the bed off of a late 80's Mazda pickup.
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 07-01-2018, 05:37 PM   #6
72LB
72LB's Avatar
I know someone near me that makes them bit they are pricey.
Not sure if this will work but they are $185 for the whole kit.
https://www.facebook.com/2corinth517...action_generic
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 07-02-2018, 08:50 PM   #7
dmjlambert
dmjlambert's Avatar
I thought what Metaldoc did here was super cool. If I ever switch to an under bed tank this is what I'll do. http://67-72chevytrucks.com/vboard/s...45#post7586745
If I keep my in-cab tank and add an under bed tank, then I'm going to use valves and pumps to move fuel to and from the in-cab tank and just not have a filler neck at all on my under bed tank.
dmjlambert is offline   Reply With Quote
Old 07-03-2018, 10:47 AM   #8
68blazer
68blazer's Avatar
Thank you for the response. I will look into it and evaluate wether its worth it to me or not.
Again, thank you
