Old 06-30-2018, 10:49 PM   #1
fastpace
Wilwood Brake Questions
So I've had Wilwood 6R 14" front and 4R 13" rear brake setup with a Wilwood 15/16" master cylinder manual brake setup for a while now and have never been able to get the brakes to feel right. The pedal is very hard and I basically have to lock my leg at a light to keep it stopped. I originally used the original master cylinder rod location on the pedal, but after reading I drilled a new hole higher on the pedal which seemed to help some. I bought a brake pressure gauge, and I'm seeing about 900-1000 psi at all the calipers which is within range. From reading more, it looks like I might benefit going to a 7/8" bore master cylinder, or remove the brake pedal assembly and drill even higher on the pedal. Any suggestions?
Also, any suggestions for brake lines for a 72 long bed? I have the Wilwood proportioning valve with mount to the master cylinder.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 07-16-2018, 06:51 PM   #2
NC_John
NC_John's Avatar
Re: Wilwood Brake Questions
Originally Posted by fastpace View Post
. Any suggestions?
Did you try getting in touch with wilwood tech support? I checked with them a couple times for recommendations on my brakes and clutch setups.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
