11-13-2003, 01:58 PM | #1 |
70 2wd to 4wd
I have a 1970 CST/10 with automatic transmission. I found a 1967 4x4 chassis. Will the 1970 body bolt right up to the 67 4x4 frame or will there need to be modifications made.
11-13-2003, 02:23 PM | #2 |
shouldnt be, should bolt up.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
11-16-2003, 02:46 AM | #3 |
Collector of rusty Items
67's had funky power steering, but you should be able to get around that.
Do you have a tcase and both axles etc? 67's had most rockwell tcase, which is hard to find parts for. but... Go for it. You might want to upgrade to a New Process 205 tcase while yo have it apart, but that is pretty easy. the frame is the hard part to find.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
11-17-2003, 11:02 AM | #4 |
check my post on 2wd to 4wd. There is a lot of good stuff on that from our members.
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
