Old 07-19-2018, 12:29 AM   #1
Patch
Patch's Avatar
1969 front turn signal LED bulbs?
Ordered up some new front turn signal lenses, want to switch to LED bulbs. Are there some tried and true bulbs for this application that don't hyper flash? I've looked around....but I'm having trouble getting it nailed down. Thanks in advance....Pat
Patch
Patch is offline   Reply With Quote
Old 07-21-2018, 12:32 AM   #2
Robznob11
Robznob11's Avatar
Re: 1969 front turn signal LED bulbs?
Not sure on tried and true bulbs...but none should hyper flash unless you go to full leds all around..
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-22-2018, 12:08 PM   #3
bill3rail
bill3rail's Avatar
I went full LED and do not have a hyper flash issue.
I bought just plain old SleazyBay LED's (1156's and 1157's).
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-23-2018, 09:15 PM   #4
Rich69shortfleet
If you use an electronic flasher instead of an electromechanical flasher it will never hyperflash regardless of what kind of bulbs you have. You may need to install two flashers, one for the turns and one for the emergency flashers.
Rich69shortfleet is offline   Reply With Quote
Old 07-25-2018, 01:10 AM   #5
Rufas
Rufas's Avatar
When I installed LEDs on my 70 didn't have a problem with hyper flashing, just no flashing at all. Needed to install a solid state flasher to get everything to work. Yes you most likely need a second solid state flasher for your emergency flashers.
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
