What fuel filter should I use?
making plans to build my fuel system. I have a in tank pump. Ill be putting a inline filter on the frame rail. What micron filter should I use? and should I put more than one filter (of different micron) in the line?
Thanks Jeff |
Post Whore
![]() ![]() Join Date: May 2015
Re: What fuel filter should I use?
Do you have a return on your fuel system?....if not you can use a vett filter/regulator....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-03-2018 at 07:03 PM. |
Sorry should have clarified that. Yes I do have a return line. I have a 4.8 from a 2000 Silverado.
Gm fuel filter gf481 works fine. I bent my own steel lines and used my mastercool hydraulic flaring tool and made the o ring ends needed for the gf481. Gm used this filter for many years on various styles of fuel injection.
