Old 11-15-2003, 12:17 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
rear sway bar / helper leafs
OK, this is sort of a few questions/comments all mixed up into one. I've seen several forms of helper leaf springs added to trailing arm trucks, but I just saw a pair that is not a multi leaf set-up, but a mono-curved helper leaf (one per side).
If a mono leaf could be mounted so that it did not apply pressure, except under load or when cornering, wouldn't it act the same as a sway bar?
sactoC10 is offline   Reply With Quote
Old 11-15-2003, 12:27 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, if that truly is how it works. An "anti" sawy bar is nothing more than a torsional spring. When you aren't applying force to either end, it doesn't do anything but sit there.
Since it is fixed in the middle, if you apply a force on one end, it applies the same force on the oppiste end to conteract body roll.
If your leaf assist was configured to apply the same type of force, it would work the same as an "anti" sway bar....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-15-2003, 02:04 PM   #3
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Your helper spring idea will work in close relation to a sway bar. N2TRUX has a very good explaination. Here is one problem though. Your helper springs will help keep the rear suspension from compressing, but NOT from drooping. Say you make a hard left turn; your right springs will want to compress because of body roll. They will have a harder time doing so because of your helper springs. Your left springs will want to extend because of the less weight druing the turn, a helper spring will not keep that from happening.
A sway bar will work better than halper springs simply because that is what it was designed to do. As you already know, it ties each side of the suspension together and tries to make it go up and down at the same time. You have a good thought going there. Don't get me wrong, your helper springs will help the problem of body roll, but just not as much as a sway bar would.
Just remember that your rear end will also ride stiffer with the helper springs when you mount them so that they are always in contact with the rear axle so that your idea will work.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-15-2003, 03:00 PM   #4
sactoC10
71 DELUX
sactoC10's Avatar
What if they were not mounted in constant contact, or say if there were large bushings installed between the contact points?
Just thinking, still...thanks.
