Part time np203 question
I know I should run my trasfer case about every 300 or so miles to spin up some lube on the bearings. My question is does it matter if I lock the hubs and dont shift the t-case or shift the t-case and dont lock the hubs? Do they both do the same thing?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Have you converted it to part time? The 203 is full-time. I know since a 208 is part time it should lube all the bearings all the time. The pump on the 208 is tied into the main shaft.
![]() Join Date: Mar 2003
Just pull the shifter back a click for a couple of miles and call it good
