leaking 205
I don't know if I can explain this well but here goes. I got a 71 K5. The output yoke on the t-case is leaking. The one that drives the rear wheels. It's also loose. You can wiggle the yoke back and forth. It has a 1/2" gap between the dust cover(behind yoke) and the aluminum cover bolted to T-case. The large nut holding the yoke on is tight. I know the seal is bad. And the 1/2" gap is where mud and stuff got in to make it go bad. Anybody have any suggestions? Know what would cause a gap but the yoke nut to still be tight? Is it possible someone put the wrong bearing or seal in it? I wished I had a pic. I know it would help. How hard is a 205 to work on? Thanks in advance for any help/replys.
Collector of rusty Items
Sounds to me like you lost a rear bearing. Is it noisy?
Look for the post about "Shop manuals for a 205 465" as it has listings on how to rebuild a 205 Also there is a guy on ebay that does rebuilds and he has good feedback on 211 sales, mostly rebuilt transfer cases http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442592083 I don't think you can beat his price. Your core probably isn't worth shipping back to him, but you can email him and find out. good luck
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
Here is a link to a site that has an article on rebuilding the NP 205.
Jim http://www.bulldogs-house.com/Projects/np205/ |
please don't break
i replaced the front out put seal on my np205. i don't know the answer to your problem but replacing the seal was pretty easy. good luck
