Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-02-2018, 10:19 AM   #1
hatzie
Moderator
hatzie's Avatar
8 lug on 6.5" 2003-09 Hummer H2 17x8.5 Seven Spoke Alloy Wheels and tires
--Four bare 2003-09 Hummer H2 Seven Spoke Alloy Wheels in Plymouth NH area.
  • 17" x 8.5" 8 lug on 6.5" bolt circle
  • GMT800 Center caps with stripped plastic lug covers.
  • Good daily driver condition. No curb rash and no corrosion but need to be cleaned. These were installed on the truck in Sacramento by the PO so there's not NorthEastern Corrosion.
  • $600 for the set.
You can pick em up locally or... Shipped FedEx ground in four 18x18x10" boxes that my new 2008 GM N89 wheels were shipped in. Weight is around 50lbs each. My best guess is probably around $100-$200 each...
--Four very new 33" Load range C tires 285/70R17 the Sacramento Dealership installed to sell the truck... or so I was told. Tread depth is such that I don't disbelieve that.
I shipped the truck cross country so they have the 100 miles from the freight terminal to my house and maybe another 50 in test drives and the drive to Wilson Tire on em.
$400.
The tires will not ship cheap and I don't have a relationship with Brown or Fedex to make it cheaper.
They rubbed when I cut the steering tight on my GMT800 and the aggressive tread made em too noisy for me on the 100 miles or so of interstate highway and 55mph 2 lane blacktop I drove between Marlboro Ma and Warren NH.
I needed heavier Load range E tires for towing etc.
The plastic GMT800 centre caps fit the wheels.
The tires are still mounted on the wheels right now.
Stock T800 lugs are double threaded 14mm. SAE double threaded lug nuts are available to use the T400 & T800 center caps or find a set of blank H2 center caps.
New plastic lug covers with good threads are available as well.
Here's how the H2 wheels look on a Squarebody...
http://67-72chevytrucks.com/vboard/s...29&postcount=2
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-06-2018, 11:16 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 8 lug on 6.5" 2003-09 Hummer H2 17x8.5 Seven Spoke Alloy Wheels
Wheels. Some road grime and brake dust that wipes off as can be seen below where my fingers wiped the dust off.
NO Northeastern Corrosion.
Old 09-06-2018, 11:22 PM   #3
hatzie
Moderator
hatzie's Avatar
285/70R17 LT Tires...
Old 09-09-2018, 09:04 PM   #4
jamie72
jamie72's Avatar
and why couldn`t you be closer to indiana...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-10-2018, 01:27 AM   #5
hatzie
Moderator
hatzie's Avatar
Wheels and tires would be 33x33x12 and probably right around 110# each.
Tire Rack just puts a cardboard disc on the outside and inside of the tire mounted on the rim and wraps with shipping plastic.
8lug, h2 hummer, tires, wheels
