Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-17-2018, 07:01 PM   #1
Boshears
2 1/2 x 3 1/2 rectangler tubbing
I'm reconnecting a Monza back halved frame that is a tube chassis for my 48 3100. I need to find some 2 1/2 x 3 1/2 tubbing. I have looked every where and can not find any. Does anyone know where I could find some? Thanks.
Boshears is offline   Reply With Quote
Old 09-17-2018, 11:07 PM   #2
Captainfab
60-66 Nut
Re: 2 1/2 x 3 1/2 rectangler tubbing
That is an odd ball size. You may have to make your own by having a 2-1/2" x 3-1/2" channel formed and boxing it with a piece of 3-1/2" wide flat bar or sheared sheet.
Old 09-18-2018, 10:05 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are you positive thats the size tubing? Half sizes in square tubing aren't super common. I think 2.5x5" is the only one I've seen. 2x3 is a common size tho, is that not useable? (by telescoping it, or modifying the box size as Cap said.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-18-2018, 04:33 PM   #4
Boshears
The actual size is 2x3, but the front clip has been cut right behind the mid plate mount. So there is not a lot of room to re connect it back together.
Old 09-20-2018, 03:36 PM   #5
Boshears
Any ideas?
Old 09-20-2018, 11:20 PM   #6
Captainfab
60-66 Nut
Ideas about what? You first said that you needed 2-1/2" x 3-1/2" rect tube and then said that what you are working with is 2" x 3". The 2" x 3" rect tube is readily available in several wall thicknesses. As for connecting, if there is not much room on the outside for a fish plate, use internal plates on both sides and plug weld the tube to the internal plates as well as welding the joint. And make the joint at an angle instead of a straight 90* cut.
Any ideas?
Old 09-21-2018, 03:33 PM   #7
Boshears
Thanks.
