09-18-2018, 10:28 PM | #1 |
C20 rear cab mounts
Hi. Has anyone had Steele Rubber re-vulcanize their C20 rear cab mounts (the "shear" style mounts with the rubber blocks)? Wondering what kind of luck you had. I worry that the re-vulcanized mounts might come back a slightly different height than the originals which would cause the cab to end up either too high or too low relative to the bed. Too low can be shimmed but too high would be a problem. Anyone have any experience with this? Thanks.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
09-18-2018, 10:31 PM | #2 |
Re: C20 rear cab mounts
mine came out great very nice work
09-18-2018, 10:35 PM | #3 |
And the height was correct? All the trim lines up between the cab and bed?
09-18-2018, 10:38 PM | #4 |
i did them on the green truck came out great going to do the red truck next
09-19-2018, 09:36 AM | #5 |
Anyone try hot riveting the bracket back to the frame or are you bolting them back on ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
