Old 09-19-2018, 03:57 PM   #1
mcrich65
89 GMC Steering Column
I am working on my 89 GMC Burb and before I starting this steering Column apart again does anyone have an exploded view of all parting and there placement, so that I can make sure I'm reinstalling them correctly.
1989 R1500 2WD column shift W/tilt and cruise
mcrich65 is offline   Reply With Quote
Old 09-20-2018, 09:41 AM   #2
Ski-me
Ski-me's Avatar
Re: 89 GMC Steering Column
I couldn't find one when I did it. Take a lot of pictures all the way through the rebuild, before you take them apart. My reference pics really helped! Especially the slide locking mechanism and spring location.
I did use some guide as reference, I'll see if I can find.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-20-2018, 09:45 AM   #3
Ski-me
Ski-me's Avatar
Found it, a PDF. Really helpful when I did it....probably twice!
It's 9MB...can't upload.
But found the link!@!
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
- Jeff
Old 09-24-2018, 06:20 PM   #4
Koz1
if you have to pull signal switch ,take pic of wire sequence,and pull each wire out of harness plug,make it so much easier pulling and putting back thru column,just went thru mine after a theft thieves ,broke plastic housing and selector easy to start after,along with breaking 1\4 glass to access. Like mentioned just take pics as you go.
Koz1 is offline   Reply With Quote
Old 09-25-2018, 12:01 AM   #5
Irish1941
Irish1941's Avatar
They are easy to do but it can be a PIA if you've never did it.
This is best basic guide I ever came across.
http://www.fieros.de/en/articles/steering.html
I know it's Fiero but pretty much basically same Saginaw column.
That other link is better for complete rebuild.
Irish1941 is offline   Reply With Quote
