L31 with mechanical clutch
Do the new L31 crate engines come drilled and tapped for the clutch cross shaft ball stud?
Thanks! Posted via Mobile Device |
Re: L31 with mechanical clutch
Mine was not, had to drill & tap.
Had to drill and tap mine to, use a sharp bit. also had to do two for the timing cover. got it running last weekend sweet engine, love it.
my 4 bolt main l31 has a hole drilled / tapped just above the oil pressure port above the filter boss area .
the hole goes in to the bell housing cavity . i think its the right one for mech clutch ? ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#6 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
It depends on what year truck you are installing the engine in. The '63-'66 trucks require the forward boss for the ball stud for the bellcrank.
It depends exactly what year of a truck you are installing the engine into.
driving is in my blood
My L31 was a take out from a 99 model and accepted a mechanical clutch in my 78 no problem. But I'm pretty sure it attached to the bellhousing not the engine. Been a while so I forget lol.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
60-66 Nut
Yes the square bodies have the clutch ballstud bolted to the side of the bellhousing.
