09-26-2018, 12:18 AM | #1 |
Electrical issue
I have a 1961 chevy c10 and I have no peower to anything headlights dash motor fuse box ect.. I have a brand knew battery cables are knew also i was wondering if anyone has had this issue if so what to look at to fix it
09-26-2018, 12:36 AM | #2 |
Re: Electrical issue
Check the positive wire connections at the horn relay. Or make sure that you have a charge wire from the battery to the horn relay in place.
09-26-2018, 07:37 AM | #3 |
Schematics and a test light. Start at the battery and work your way through.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
09-28-2018, 01:17 PM | #4 |
check your grounding.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
