09-28-2018, 03:49 PM | #1 |
Room for bigger tires!
Ready to upgrade that tired suspension system? Want more flex off road or a better ride on road? We have everything your truck needs to fit those bigger tires. Who doesn’t like a Chevy with some big meats on it!
https://www.offroaddesign.com/catalog.htm We offer kits and individual pieces to get you where you want, from 2” to 12” of lift. One of the most popular items is the Rear Shackle flip. The flip can get you either 2.5” or 4” of lift. This is a better way of lifting the rear over using Lift Blocks. For leaf springs we have options from Tuff Country EZ rides to our Custom Springs. The Custom Springs give you the ultimate in on rode ride (keep those passengers happy) and off-road flex. These springs are tailor made for your vehicle, unlike the off the shelf lift spring that is one size fits all. Add to the strength and longevity of your truck with the Front Upper Shackle Hanger (FUSH) kit. The FUSH replaces the tiny hanger that comes from the factory, giving you the ability to run a bigger bolt and bushing We have the Heavy-Duty front and rear shackles to replace those thin factory ones. Don’t forget to top off your new lift with Extended Brake lines, U bolts, Shocks, Extended Bump Stops, Sway-bar Disconnects and Steering If you have any questions send us a PM or give us a call at 970-945-7777, we love to talk Truck! |
10-01-2018, 03:43 PM | #2 |
Re: Room for bigger tires!
Just placed an order.
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
10-01-2018, 04:41 PM | #3 |
Awesome! Thank you for the order!
10-06-2018, 02:49 AM | #4 |
I’m interested in the FUSH kit. What’s the pricing on it? I already have your lift kit with the heavier shackles, but I was unaware of this upgrade.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
10-08-2018, 11:19 AM | #5 | |
Thank you!! |
10-10-2018, 08:22 PM | #6 |
I have your shackle and greasable bolt. Can I reuse the bolt I have?
10-11-2018, 11:54 AM | #7 |
10-12-2018, 06:41 PM | #8 |
So do I need to buy a new bolt for the frame side to be greasable? I have a greasable bolt that came with the shackle kit. Are they different?
10-12-2018, 07:08 PM | #9 |
