10-04-2018, 08:58 PM | #1 |
vintage air install question
just got a vintage gen iv and was wondering how you all ran you heat/cooling lines, I smoothed my fire wall for a clean look and really dont want to go through the fire wall in the engine bay.I was thinking of running the lines under the fender well then through the fresh air vent cavity , then pull through the vent kick pannel then to the evaporator. Has anyone does something like this? always open to suggestions. thanks , Mike
10-04-2018, 09:57 PM | #2 |
Re: vintage air install question
On my '51 I went under the inner fender from the front and into the cab under dash high in the kick panel area. I also made my own bracket for the compressor mounting below the heads. It cleans it up nicely so one can seamlessly enjoy the nostalgiia of the truck without distraction.
You will possibly need a few different fittings with different bends and longer hoses but easily do-able. Get some zip ties and some heater hose and try some mockups. |
10-05-2018, 01:10 PM | #3 | |
10-05-2018, 02:36 PM | #4 |
the 5th gray line is all the wiring for the front lights, ac and fan. 2 wires behind the distributor are temp sensor and starter
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-05-2018, 05:08 PM | #5 | |
10-05-2018, 05:40 PM | #6 |
vintage air sells grommets and it may work to your advantage to go through the kick panel. I used two mini vintage air systems on the last couple trucks and for whatever reason they like the fittings to come out the SIDE of the system, pointing at the kick panel, all 4 connections. if you tried to go through the firewall like I did you would need a 90 degree turn, and thats harder to plan length for and can pull the grommet this way or that.
does electricity flow more efficiently in a hose than a wire?
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
10-05-2018, 08:11 PM | #7 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
10-05-2018, 09:01 PM | #8 |
thanks everyone , you all have great solutions , cant tell you how much i appeciate it
10-06-2018, 02:01 PM | #9 |
I also smoothed my firewall and didn’t want a bulkhead to show. It went through the kick panel area, the hoses are in the wheel well and come in as low as possible on the passenger side inner fender.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 10-06-2018 at 02:20 PM. |
10-06-2018, 02:49 PM | #10 |
I'm running mine through the fenderwell. See the 4 holes to the left in first pic and the manifold in the 2nd pic. Hoses will be "grommeted" coming through the firewall, and I made a u-shaped bracket to hold them close to the inner fender. The small hole in the center of the 4 holes is for the trinary switch wiring. The bracket and the dryer are mounted on welded-on studs on the tire side of the inner fender (not shown).
NOTE: Checkered flag in pic is only masked. No paint yet. It will be a ghost flag when done, I hope. New territory for me.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 10-07-2018 at 09:16 PM. |
10-07-2018, 08:45 PM | #11 |
Hi Buddy, I wish I cold help you, I've only done this on my streetrod. If that would be of any assistance, just call or text me.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 10-07-2018 at 09:02 PM. |
10-08-2018, 12:50 AM | #12 |
Works for me!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
10-08-2018, 09:49 AM | #13 |
thanks so much for the pics, looks great
10-08-2018, 09:51 AM | #14 |
thanks morrie, i appreceate it
10-08-2018, 09:53 AM | #15 | |
10-08-2018, 12:52 PM | #16 |
Thanks, slammed. Shot the copper pearl this morning. Unmasked. I don't want to hijack the thread, so I'll just say, see the "What did you do with your truck today, part 3" thread in a couple of days.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
10-08-2018, 03:21 PM | #17 |
will do! lookin forward to see it
