Best Abrasive Disk for Silicon Bronze Welding
We are using Silicon Bronze wire in a MIG welder to weld in some patch panels and weld up the center seam in the hood. Any recommendations on the best abrasive disk (for my grinder) for grinding down the silicon bronze weld?
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
![]() Join Date: Aug 2012
Re: Best Abrasive Disk for Silicon Bronze Welding
Free?...Just kidding...
I'd say a couple of 40-60 grit flap disks. Try to move around and take breaks to keep the heat down. |
I will add to Iowaboy, as I put in my "Basics of Basics" when referring to sand paper when blocking primer or bondo, you want NEW, SHARP, QUALITY discs so you CUT the weld and not polish it! CUTTING the weld quick reduces heat, it reduces damage because you can locate JUST what you want to remove easily.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#4 | |
Wade
Post Whore
![]() ![]() Join Date: May 2015
3M roloc disc work great...you can quickly change grits and the scorchbrite disc and bristle disc also fit the same backing pad...
#6 | |
Brian
