Old 10-12-2018, 01:30 PM   #1
8man
Door hinge rebuild
I found the 4th hinge and now I'm starting the rebuild. I have them all apart, what a chore! I had to weld two of the little washers back into the base part of the bracket, their welds broke loos while taking the hinges apart. I had to use heat and PB and a BFH to get them apart. That brings me to my question.
I may have spread the base part of the hinge when driving the pin out.
So my question is how tight should the base fit to the arm? should it be tight, a little loose, or dose it even matter?
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 10-12-2018, 02:57 PM   #2
mick53
Re: Door hinge rebuild
I wouldn't want any slop in them. There are some nice videos on youtube on these rebuilds.
mick53 is offline   Reply With Quote
Old 10-12-2018, 04:09 PM   #3
b-mac
b-mac's Avatar
If your pins stay solid, it shouldn't matter. But inevitably, they will wear out. At the point where you have slop in the pins, that distance between the two parts of the hinge could matter some, but not much.
Still, it might be worth it to get them in a vice and get them pretty close to tight, without causing friction between the two surfaces.
BTW, my hinges were a b**** too. Wish I had just bought some. As straight as I tried to drill the hole (went with the larger aftermarket pins) I think I got it a little off. Thus, I've had to do a ton of trimming/wollering out the holes on the hinges, to get the doors to close correctly.
I also did a lot of moving my cab without the doors on...not recommended.
b-mac is offline   Reply With Quote
Old 10-12-2018, 04:59 PM   #4
8man
Thanks guys.
I couldn't stand it so I did put them in a vice. They are not tight, but very little daylight shows when they are put together.
I have the pins, and need to drill the hinges so the pins fit. I watched the hinge rebuild done for The Filling Station, but he doesn't show the actual work, so I am guessing here.
I am thinking that I can use my vise on my drill press to hold the hinges while I drill the holes. Hopefully that will work.
8man-aka Robert
Old 10-12-2018, 06:13 PM   #5
mr48chev
mr48chev's Avatar
Brothers You tube video that makes it look easier than you figure on
https://www.youtube.com/watch?v=KSvdCLdCGpY
My ongoing truck projects:
Old 10-12-2018, 06:35 PM   #6
8man
Thanks. It's funny, I just watched that one.
I wish someone would show drilling the pin hole in the AD hinge.
8man-aka Robert
Old 10-12-2018, 06:36 PM   #7
OrrieG
OrrieG's Avatar
this is for AD trucks but TF is the same process.
https://www.stovebolt.com/techtips/d...ges/index.html
OrrieG is offline   Reply With Quote
Old 10-12-2018, 06:48 PM   #8
8man
Orrie, I was making it much more difficult to drill out the hinge pin hole. I think I can drill that. Also, thanks for the intro to Stovebolt. I hadn't been there before.
8man-aka Robert
Old 10-13-2018, 10:20 PM   #9
cmayna
Did mine 7-8 years ago. Not really that difficult, but having a drill press really makes life much easier.
Craig
My truck '50 Chevy 3100-5 window
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
cmayna is offline   Reply With Quote
Old 11-01-2018, 11:21 AM   #10
boulis54
I’ve done a few other vehicle hinges along with doing mine to my 54. I’ve found usually if you start out small and keep going up in size with the drill bits that when you come to the edge of pin you can stop and then use a punch and hammer to knock out rest of pin. Which will keep the original locate. Mine were very rusted and seized up. Take your time and good luck
boulis54 is offline   Reply With Quote
Old 11-01-2018, 12:04 PM   #11
MARTINSR
MARTINSR's Avatar
Here is a "Basics of Basics" on the subject. https://www.hotrodders.com/forum/bas...es-125350.html
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-01-2018, 12:08 PM   #12
8man
Thanks Brian. I have that one printed off and wish I had seen it sooner. I had to figure out the hacksaw trick on my own. Luckily I had a spare hinge because I broke one trying to beat the pin out.
I hope to prime and drill the parts this weekend.
8man-aka Robert
Old 11-02-2018, 12:24 PM   #13
65blackfleetside
65blackfleetside's Avatar
I rebuild my upper (No easy task getting it apart) . Bought the kit from filling station reassembled hinge but the top of the door needs to be pulled out 1/4" away from cab.
I have tried slotting the holes in door and the vertical hinge adjustment. I think this hinge was tweaked inward many years ago.
Does anyone have any ideas on how to bend an AD hinge?
I have a large pipe wrench but my vice is not anchored strong enough to pull that hard on.
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B]
1965 fleetside Sold
65blackfleetside is offline   Reply With Quote
Old 11-02-2018, 12:33 PM   #14
MARTINSR
MARTINSR's Avatar
Can you post some photos of exactly how the door is fitting, far and near photos. A LOT Of time the top being out if often because the bottom is IN. Is it out at the front of the door or the rear of the door?
Brian
1948 Chevy pickup
Old 11-02-2018, 01:34 PM   #15
NorCalGal
NorCalGal's Avatar
I know how, but the where is hard to tell without seeing it. I heated mine up with a torch til it glowed where I needed it to bend then used 2 large crescent wrenches to bend.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 11-02-2018, 03:19 PM   #16
65blackfleetside
NorCAl Gal-Here are some picts of the problem. The upper door frame hits on the windshield pillar before the rest of the door can close. I am thinking top hinge it needs to be bent out? What do you all think?
1965 fleetside Sold
Old 11-03-2018, 03:23 AM   #17
NorCalGal
NorCalGal's Avatar
Looks like the lower cowl was replaced and positioned to far back causing it to hit the lower front edge of the door. If you flatten just the upper hinge and take some of the bend out it's going to suck the door in towards the steering wheel and drop the back of the door down causing more problems. Do you have room to slide the door towards the back of the cab without hitting the latch, it would fix the problem with the upper door frame hitting but would leave you with a larger gap at the front edge of the door which you could adjust by using some small filler rod and weld to the front edge of the door until you have a 3/16 or so gap even top to bottom.
Does this make any sense?
Jan's 53
Old 11-03-2018, 08:27 AM   #18
65blackfleetside
"Looks like the lower cowl was replaced and positioned to far back causing it to hit the lower front edge of the door. If you flatten just the upper hinge and take some of the bend out it's going to suck the door in towards the steering wheel and drop the back of the door down causing more problems. Do you have room to slide the door towards the back of the cab without hitting the latch, it would fix the problem with the upper door frame hitting but would leave you with a larger gap at the front edge of the door which you could adjust by using some small filler rod and weld to the front edge of the door until you have a 3/16 or so gap even top to bottom.
Does this make any sense?"
Unfortunately the door is slid back as far as it can go. If door goes back any further it hits the rear door jam. I even used my drimmel to elongate the door holes. I also tried adjusting the other set of hinge bolts. No Luck. I feel like the bottom is out the opposite way as in facing too far out which makes me think this hinge is torqued?
I saw where someone else bent the curved part of the hinge out an 1/8" of an inch with a large pipe wrench with hinge off and in a large vice- My vice is the weak part in that equation. I attempted this but vice is mounted to wood surface so If I pull any harder on it vice will come loose.
I guess I could put some heat on it?- but I don't want to mess up my newly rebuild hinge.
1965 fleetside Sold
Old 11-03-2018, 12:04 PM   #19
MARTINSR
MARTINSR's Avatar
Post a photo showing the rear door gap to the back of the cab too.
Brian
1948 Chevy pickup
Old 11-03-2018, 12:17 PM   #20
vintovka
vintovka's Avatar
Ditto on poor fit as shown above. I rebuilt my hinges on both side but the drivers is terrible. It was a replacement and from a 53 (instead of a 54). Going to pull door soon and bend hinges. Tired of seeing daylight at top and hearing wind noise all the time. Will try to post results.
vintovka is offline   Reply With Quote
