Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 10-12-2018, 03:48 PM   #1
cff
Active Member
348/409 differences
I'm looking at buying a C80 that supposedly has a 409 in it. How can I tell the difference between a 348 truck engine and a 409 truck engine. Is the dip stick position different on the truck engines like on the car engines. Thanks for any help.
cff is offline   Reply With Quote
Old 10-12-2018, 11:36 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 348/409 differences
Checking the Casting Numbers, Date Codes and Engine Suffix Code will also help to tell what you have there.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 10-17-2018, 11:20 PM   #3
Biscayne Stocker
348 and 409 truck oil pan are exactly the same. Dipstick on the passenger side. Check the #s like Bill said
Biscayne Stocker is offline   Reply With Quote
Old 10-23-2018, 03:56 PM   #4
cff
Active Member
I seen somewhere's where someone said there's an X on the front of the block on 409's by the water pump on the driver's side. Does anyone know if this is true?
