Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-19-2018, 02:53 PM   #1
Offroad Design
Offroad Design's Avatar
All the lift without the blocks
Lift the rear of your truck without sacrificing ride quality or adding lift blocks that lead to axle wrap.
The Offroad Design Shackle Flip changes your tension shackle to a compression shackle gaining you the lift you want. We make our Shackle Flips in 2.5” or 4” Lift.
https://www.offroaddesign.com/catalog/shacklekit.htm
Our shackle flip bolts in place of your stock hanger utilizing the original bolt holes making an easy install process.
Name:  73-87 flip3.jpg
Lift springs use a higher spring rate which means a rough time for your teeth as you drive over pot holes. By using a shackle flip you still get the lift height with stock spring rates.
Lift blocks can fall out over time, they also magnify axle wrap. No Bueno!
Our shackle flips can utilize your stock shackle. Or if you are looking to upgrade check out our HD Rear Super Shackles in 4.5” and 6”!
Name:  4.5 Inch Rear Shackles.jpg
Don’t forget those U bolts.
Give us a call at 970 945 7777 or check them out at
Offroad Design is offline
Closed Thread
