10-30-2018, 12:11 PM | #1 |
exhaust system
I am changing over from single exhaust to dual on a 1970 c10 4x4 (yes, title says c10 though it is a factory 4x4).
I have the original ram's head exhaust manifolds. everywhere i look seems to be really expensive. does anyone sell the flexible tubing anymore- that i could use/ create my own exhaust system rather than dropping 4-500 bucks? |
10-30-2018, 01:19 PM | #2 |
Re: exhaust system
I built my own, have about $275 for it all including mufflers. You'll need a welder or oxy/acetylene. (that's for 2.5" I'm running vette rams horns.)
You might find an exhaust shop that could do it for not much more & it would look better due to less welds. |
10-30-2018, 10:56 PM | #3 |
Re: exhaust system
A kit from Heart Throb exhaust. LMC is a dealer. The fit is good. And it is mandrel bent. Not sure if any other vendors deal with Heart Throb.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
10-30-2018, 11:56 PM | #4 |
Re: exhaust system
X2 on Heartthrob, I forgot about them. I've used their kits before & they fit well. They didn't offer a 2.5" kit or I would have used them instead of building my own.
10-31-2018, 09:23 AM | #5 |
Re: exhaust system
I had 2 driver side pipes from my 79 that I put on my 71 with only 1 small mod. Went right on with no issues. Basically 1 bend in them.
10-31-2018, 01:51 PM | #6 |
Re: exhaust system
X3 on Heartthrob. I put their dual system on my 1971 1/2 ton 4x4 more than 16 years ago (I remember doing the job in the driveway of a house I sold 16 years ago).
The only thing missing in the box they sent to my doorstep was a frame hanger for the side that doesn't have the factory hanger for single exhaust. I used a generic piece from the local NAPA. FWIW, I ordered my kit from LMC truck before it was fashionable on this forum to say bad things about them.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-31-2018, 02:53 PM | #7 |
Re: exhaust system
I have a Heartthrob exhaust on my 2WD 3/4 ton. It works well. Great customer service from Heartthrob also. I bought mine at Auto Accessories Garage. It costs less than from LMC after the 20% discount AND shipping is free. Here's a link to the 4WD system with the "stock" mufflers and behind the tires exit. Other mufflers (or none) and rear exit versions are also available.
https://www.autoaccessoriesgarage.co...?set-vehicle=1 |
11-22-2018, 12:25 AM | #8 |
Re: exhaust system
chahanging my 67 K10 from a 6 to an 8. I would have used Heartthrob but their system will not work with a T221 transfercase. I have rams horns and am using flexpipe till I can get to a muffler shop. Advance auto parts sells them about $10 each
Tags |
exhaust |
