11-10-2018, 08:38 AM | #1 |
Step up Patch
I’m considering purchasing a 71 burb and it has an area of rust on both sides at the step up to the cargo area. Is a patch panel available for this area?
11-10-2018, 03:31 PM | #2 |
Post Whore
Re: Step up Patch
Not to my knowledge. But either way here is the best thread I have encountered on the subject. For what it's worth if that is the only rust on the Burban I would find it hard to pass it up.
http://67-72chevytrucks.com/vboard/s...d.php?t=724682 P.S. Thanks to 04ls1gto for post his fine work.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 11-12-2018 at 02:40 PM. Reason: Added post script. |
11-10-2018, 08:59 PM | #3 |
Re: Step up Patch
Check out my thread on fixing this, it was a huge amount of work. I had to remove plywood floor and replace and it's going to be a lot worse then it looks
11-10-2018, 09:09 PM | #4 |
Re: Step up Patch
11-10-2018, 09:33 PM | #5 |
Re: Step up Patch
That’s what I was afraid of. I haven’t seen it in person yet and if it looks like that on both sides I can only imagine how bad it really is.
11-12-2018, 09:00 AM | #6 |
Re: Step up Patch
You can see in 04ls1gto's thread that his crossmember is rotted away too. In my case the crossmember is pretty solid but rust has gotten between it and the inside sheet metal.
Look in from the wheel well side.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
