11-13-2018, 03:20 AM | #1 |
Rear end for LS
What is a good donor rear end for an LS swap? it is coil spring, so i believe its easier...
11-13-2018, 08:22 AM | #2 |
Re: Rear end for LS
The one that's in it.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-15-2018 at 12:11 AM. |
11-13-2018, 10:11 AM | #3 |
Re: Rear end for LS
I'm in the middle of a swap. I'm just using my same rear end that has 3.73 gears in it. I decided to pull it all part and replace bearings, seals, gaskets, rear dif cover, and intall a new eaton trutrac carrier. Just about finished with it. From what I've read, it's not so much the rear end that needs swapped but possibly the gear ratio depending on what transmission you decide to use with your swap? Also, (and I'm not this far along yet) you need to decide how to get the power from the trans to the rear end. There are some decisions to make in deciding whether to get a custom driveshaft, center carrier issues, and maybe might be able to get by with some yoke modifications to original stuff. I'll know more on this later.
11-13-2018, 04:54 PM | #4 |
Re: Rear end for LS
Agree. If you add overdrive you may want a different ratio-but might be just fine. What is wrong with what you have?
If you decide to change, 3.42 is a nice overall gear for a driver with relatively tall tires and overdrive.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-13-2018, 09:51 PM | #5 |
Re: Rear end for LS
You asked what "rear" not what "gear". A 12-bolt is fine. What ratio do you have now? What transmission? What tire size? What will your primary use be?
11-14-2018, 02:52 PM | #6 |
Re: Rear end for LS
Thanks for the help! but just to be clear i can use the 69 stock rear end? I had an uncle tell me it needed to be changed but hes never done one so im glad i asked.
11-14-2018, 02:57 PM | #7 | |
Re: Rear end for LS
would i need to switch to disc brakes? just trying to figure out how much work i actually need. ill probably buy an entire car for the motor. what else would i need or can use from the donor? |
11-15-2018, 10:25 PM | #8 |
Re: Rear end for LS
I have a 2001 4x4 Silverado with the 5.3, 4l60, with 3.73 gears. That is what came standard on the Z71.
If you are putting the LS/4l60 combo, then most came with either 3.23, 3.55 or 3.73. I am sure there are some with higher of lower gear ratios.... As someone else mentioned, we really need to know what combo LS you are going with, to be able to suggest an appropriate ratio. As far as the current axle, you should be fine. I doubt you will need disk brakes in the rear at this point. It would be a great upgrade in the future, but you will have enough on your hands with the LS swap. I hope this helps. Thanks, OldMoparsRule!
1968 GMC C2500, 327/T400, Dana 60 w/ 4.11's, original working AC, disc brakes |
11-15-2018, 10:41 PM | #9 | |
Re: Rear end for LS
As far as gears like a bunch of guys have posted it really depends on your trans, tire height, and what you plan to do. A rock crawler and a highway cruiser need very different gears. |
11-16-2018, 08:42 AM | #10 |
Re: Rear end for LS
You'll probably e using the motor, transmission, harness, and computer from the donor. So you will have overdrive. My guess is you have 3.08s because of the TH350, but maybe with 6cyl 3.73 was standard. If 3.73s I think you'll like that. 3.08s might be good but kinda lanky with O/D. You will want to go to front disc brakes. The rear discs are an option for later on down the road you may or may not want. But not a concern at this point
01-07-2019, 02:15 PM | #11 | |
Re: Rear end for LS
01-07-2019, 02:26 PM | #12 |
Re: Rear end for LS
Just freshen up that rear and you can focus on the swap.
01-07-2019, 11:59 PM | #13 |
Re: Rear end for LS
the factory 12 bolt is plenty. with a 4L60 transmission, you have the advantage of an overdrive. You could get away with a 4.11 rear gear if you wanted and still be ok on the highway.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
