Old 11-21-2018, 08:39 PM   #1
jpgl
Junior Member
1970 rearend
i am looking for a posi rear end for my 1970 gmc .i have the chance to buy one from a 1978 blazer with 4.10 gears .can i install this center section in my housing or is it to new?
jpgl is offline   Reply With Quote
Old 11-22-2018, 12:30 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 1970 rearend
Your existing carrier needs to be 3:73 or up. Otherwise, the 4:10 wont fit unless you install a "thick" ring and pinion set on 4:10 posi carrier. Scroll down to 12-bolt truck... http://www.differentials.com/technic...arrier-breaks/
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-22-2018, 12:57 PM   #3
jpgl
Junior Member
Re: 1970 rearend
thank you that shows the difference know what to look for now
Old 11-22-2018, 01:06 PM   #4
Mike C
Mike C's Avatar
Re: 1970 rearend
I guess he didn't say if he was changing gears as well so I will assume he is going with the 4.10's and the posi from the Blazer. I would also hope that this is an aftermarket posi and not a 12 bolt "Gov-Bomb" that would have been factory in a '78. If it is the Gov-Lock it is most likely a 3 series with a thick gear.
If the Blazer is a 12 bolt you can swap the parts out. Buy the book on rebuilding 10 and 12 bolt Chevrolets. Check the pinion depth in Blazer 4.10 unit. Check the backlash in Blazer setup. Remove c-clips and pull axles. Remove carrier and ring gear. Remove pinion gear. Put pinion gear in '70 housing. Check pinion depth. Adjust to match what it was in Blazer housing. Put carrier and side shims in same as they were in Blazer housing. Adjust backlash.
BUY THE BOOK THAT TELLS HOW TO DO THIS AND SHOWS THE TOOLS YOU NEED!
I encourage everyone to do as much work as they can for themselves. But this job needs a little more info than you will get from asking on a message board post IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
rear end
