Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-22-2018, 11:02 AM   #1
Frugalmeyer
1972 Blazer Coil Spring Suspension
I came to the conclusion that I was not totally happy with the ride and braking of the stock suspension and decided to perform some upgrades.
Frugalmeyer is offline   Reply With Quote
Old 11-22-2018, 11:07 AM   #2
Frugalmeyer
Re: 1972 Blazer Coil Spring Suspension
Took some measurements and pics of the front end before I started.
Old 11-29-2018, 06:55 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
What’s the plan? Always liked this one
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-29-2018, 08:33 PM   #4
Frugalmeyer
I am missing a security token, sent a message to the administrator to see how to fix it. Will not allow me to post photos at this time.
Old 11-30-2018, 02:08 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Usually that happens when your pics are too big or too many. Try reducing size or post no more than two at a time
-Chris
Old 12-02-2018, 01:32 AM   #6
Frugalmeyer
Getting everything ready for the front coil over suspension.
Old 12-02-2018, 02:47 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Nice. Which kit are you using?
-Chris
Old 12-02-2018, 11:37 AM   #8
Frugalmeyer
I chose QA1 because I did not feel like removing the cross member.
Old 12-02-2018, 11:44 AM   #9
Frugalmeyer
Checking the ride height, wheel offset and look.
Old 12-02-2018, 12:00 PM   #10
Frugalmeyer
Changing to four wheel disk brake master cylinder, proportioning valve and hydro boost.
Old 12-02-2018, 12:13 PM   #11
Frugalmeyer
Measuring and preparing rear of truck for coil spring rear end.
Old 12-02-2018, 12:17 PM   #12
Frugalmeyer
Getting ready to remove POL cross member and go back to original.
Old 12-02-2018, 12:21 PM   #13
Frugalmeyer
Modifying cross member for exhaust pass through.
Old 12-02-2018, 12:24 PM   #14
Frugalmeyer
Thanks Gringoloco. I tried posting four photos instead of five and the security token did not block me.
Old 12-02-2018, 04:03 PM   #15
72gmguy
72gmguy's Avatar
Why the switch back to the stock trailing arm cross member? Something you didn't like about the pol version. Just curious.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 12-02-2018, 05:11 PM   #16
Frugalmeyer
POL cross member is flat and the rear control arm brackets are angled.
Stock cross member is angled and the brackets are straight.
Since I am going to a TCI rear coil over kit I noticed their rear control arm brackets are straight and had to go back to a stock cross member.
Old 12-02-2018, 05:23 PM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Very cool. Are you having to modify the upper coilover mounts to work with your 4wd frame?
-Chris
Old 12-02-2018, 05:30 PM   #18
Frugalmeyer
I am in the process of having a custom set of C-Notch plates made with upper coil over mounts. I will update the thread when they arrive and I begin to install them.
