Old 11-23-2018, 01:37 PM   #1
ckhdJr.
1972 front hub swap
Good morning everyone, I was just curious if anybody knew if a 1997 c1500 front hub/spindle would fit onto a 1972 c10 hub? I'm trying to put abs onto my 72.
-Ckhdjr.
ckhdJr. is offline   Reply With Quote
Old 11-24-2018, 10:22 AM   #2
dirtyjim
dirtyjim's Avatar
Re: 1972 front hub swap
it can be done but so far I don't think anyone has been able to get camber close enough to align it without shortening the lower control arms or moving them in. you have to use 3/4 ton lower control arms for the lower ball joints to fit or weld in a larger ball joint sleeve. there was a write-up on using those spindles for a 6 lug disk brake swap using light duty 3/4 ton 6 lug rotors in the suspension section
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 11-24-2018, 11:51 AM   #3
jocko
jocko's Avatar
Originally Posted by ckhdJr. View Post
I'm trying to put abs onto my 72. -Ckhdjr.
Now THAT'S something you don't normally read in someone's very first post Welcome to the forum!
Old 11-24-2018, 09:10 PM   #4
ckhdJr.
Thank you very much, I appreciate it.
-Ckhdjr.
1972, 1997, abs, c10, swap
