Old 11-25-2018, 11:25 AM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Plastic or Bronze Hatch Hinge Bushings?
I'm replacing the bushings and pins on my hatch hinges. The old bushings (which I believe are original) are plastic (just like I found in the doors when I did those).
1) Should I go with bronze bushings in the hatch? (Shouldn't corrode or get stiff being exposed more than the door hinges?)
2) From pictures I've looked at, I think the pin heads should be on the outside on both (driver and passenger side) hinges?
I'm using Napa 675-5143 which includes bronze bushings.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 11-26-2018, 02:56 PM   #2
cleszkie
cleszkie's Avatar
Re: Plastic or Bronze Hatch Hinge Bushings?
I'm certain that the door hinges should have bronze bushings. Not sure why yours were plastic. I believe the hatch hinges should also be bronze based on my experience.
cleszkie is offline   Reply With Quote
Old 11-26-2018, 04:03 PM   #3
1rippen6
Hatch hinges were plastic but the bronze will work just fine. I've never seen the plastic ones offered in any kits if you found some can you provide a link.
1rippen6 is offline   Reply With Quote
Old 11-28-2018, 11:05 PM   #4
badpeanut
badpeanut's Avatar
The plastic bushings I took out of the passenger door are still useable, but not great. I'll go with new bronze then for the hatch.
'70 GMC LWB trailer
