Old 11-28-2018, 01:36 PM   #1
extd56
extd56's Avatar
New lift kit
I put a Skyjacker lift kit on a 71 Jimmy frame and the e brake cables seem to be a little tight. It supposed to be a 2.5 lift in the rear. When I put the tub back on how much will the frame move with the weight. Do I need to get new cables and if so where to get them. Thanks
extd56 is offline   Reply With Quote
Old 11-28-2018, 07:28 PM   #2
Blazerowner
Blazerowner's Avatar
Re: New lift kit
Got it installed hu. You should see what the 3” did to mine. Huge difference from the old saggy stock springs.
Inline tube used to make them. I heard they don’t anymore, so I wonder if there is anyone else.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 11-29-2018, 04:09 PM   #3
extd56
extd56's Avatar
Re: New lift kit
So what did you do for cables
Old 11-29-2018, 04:23 PM   #4
Killer Bee
Killer Bee's Avatar
Re: New lift kit
Inline Tube referenced around the forum quite often..
may be able to search for some threads referencing your application..
Inline Tube / Parking Brake Cables
or give them a call to see what they offer..
good luck!
Old 11-30-2018, 12:28 AM   #5
JackB
Re: New lift kit
I did a Tough Country 2 inch lift and had the same concerns. When I put the tub back on I got the slack I needed.
JackB is offline   Reply With Quote
Old 11-30-2018, 09:36 AM   #6
72gmguy
72gmguy's Avatar
Re: New lift kit
Agreed. I did the 2 1/2 inch all spring lift on my 70 blazer and they were fine.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 11-30-2018, 08:35 PM   #7
Mike C
Mike C's Avatar
Re: New lift kit
I have 4" National Springs on the back of my Jimmy and the stock length cables have always been fine.
My kids Jimmy project is tub-off-the-frame in the driveway right now and the driveshaft and shocks are both WAY too short. I'm thinking it's going to move quite a bit with the tub back on based on my previous experience with my own truck on how everything fits with that same combo.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-02-2018, 11:00 PM   #8
Blazerowner
Re: New lift kit
I was going to use the stock cables so I don’t know yet.
Kirk
66 Nova
