12-04-2018, 11:17 PM | #1 |
383 Fuel Pump?
I have a side project...a 69 land cruiser with a fuel injected 383 Chevy. Trying to figure out how to calculate the fuel pump psi..or should I just go over and put a regulator? If so what psi should it be set at? Any help or clues to figure it out would be sorely appreciated.
12-04-2018, 11:28 PM | #2 |
Post Whore
Re: 383 Fuel Pump?
What type fuel injection you have?...better to be over and control with a regulator
12-05-2018, 05:09 AM | #4 |
Post Whore
Re: 383 Fuel Pump?
Youll need something capable of 85pph and 21psi.....according to the specs
12-05-2018, 10:45 AM | #5 | |
Re: 383 Fuel Pump?
Thanks but that's not entirely true. 60 PPH@12 PSI 85 PPH@21 PSI
To quote a Holley rep when I asked this question: Quote:
12-05-2018, 11:14 AM | #6 |
Post Whore
Re: 383 Fuel Pump?
Gotcha....the holley rep wouldnt recommend one ?
12-05-2018, 02:37 PM | #7 |
Re: 383 Fuel Pump?
22psi doesn't sound high for FI. Just run a pump into a regulator then adjust to your engine's needs.
My big block with 4 80#/hr injectors runs happily at a regulated 35 psi on a return line system. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
12-06-2018, 12:21 AM | #8 |
60-66 Nut
Re: 383 Fuel Pump?
I think first you will need to come up with an approximate HP number that the 383 is developing. Then the necessary fuel flow can be calculated.
https://fuelinjectorclinic.com/hp-calculator
12-09-2018, 05:56 PM | #9 |
Re: 383 Fuel Pump?
You need to know the approximate HP of your engine. Use a program like desk top dyno or the Comp Cams calculator. Then you can calculate your fuel pressure based on injector size.
If you are running a modified GM TBI setup you will need the ECM tuned or run a program like Tuner Pro so you can tune it yourself. If you run Tuner Pro it has a utility that you can plug your #s into & play with different fuel pressures. For example, I have a 383 with a big block throttle body & 80# injectors, my fuel pressure is set at 22 psi. This setup will support 393 HP. Obviously, if you have a 200 horse motor & run 80# injectors at 22 psi you will be over fueling. That's why it's important to know your approx. HP. (What Captainfab said, just more words!) Here's a link with a lot of info: https://www.dynamicefi.com/Tune_Intro.php |
