a close friend of mine has a 72 3/4 ton 4x4 and has purchased a new 632 bbc that he will be putting in his truck. What are some things he is going to need/rework to get this beast to fit. thanks
Re: anyone done a 632 BBC swap in a 72?
That's a tall deck motor, so about the only thing I can think of is booster to valve cover clearance. But it's not tight in stock form, but with tall covers to clear roller rockers plus the deck height... worth measuring.
Also exhaust has to be totally custom because the heads sit higher. Was the 596 really not enough? That's available in short block, bolt-in in place of a factory 402 ;-)
ive been trying to find a hood for the truck because i know that it will not fit with the factory hood. been looking for the smallest cowl hood that is very suttle looking but havent had any luck. something that looks as close to stock as possible and it has to be steel not fiberglass...
also, ran into some clearance issues with the front of the engine and radiator. does anyone make a lopro pulley kit or something that will bring the front accessories in? this truck will retain a/c and all. or is pushing the radiator farther forward the only way? |
![]() Join Date: Oct 2009
Hmmmm.. My slo-poke 72 K20 has a piece o crap swap motor in it. Hmm... I wonderrrrrr what your buddy is gonna doooo... with his puny 'ol worthless 350?
![]() ![]() ![]() ![]() ![]() Good luck with that swap, sounds pretty ambitious. Is this for a monster truck or a stock-ish (otherwise) K20 with a hefty driveline? Curious what other mods and driveline are in store for the truck. |
it is a factory 454 truck so that motor has been pulled already! its on 35" bfg all terrains with a 4 inch lift. I will post a picture of the truck.
![]() Join Date: Jul 2015
here is the truck that the 632 is going in.
![]() Join Date: Oct 2015
Very nice looking truck. Nice looking shop as well.
#10 | |
That is a great looking truck. But there were no factory big block 4x4 trucks from 67-72 and the 454 wasn’t installed in a truck until 1973. If it had a big block installed at some point, the 632 will go in as well. Just be warned that exhaust is a PITA on a tall deck motor.
#13 |
![]() Join Date: Aug 2004
Very nice looking truck!
The factory 2wd BBC trucks used the short water pump accessory drive. I think early Chevelles had the same parts. It is kind of tight but very do-able.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#14 | |
#15 |
#16 |
#17 |
#18 | |
#19 |
So the lift on the truck is not a kit. The springs were custom made and arched to his wanting. the rims were also made to 10" wide to accommodate the correct offset and width that he needed to fit and clear the 35" bfg's
#20 |
Thanks brother! do you know who made the rims?
#21 |
nice lookin' rig to start with!
here's a big brodix I looked at in a '71 K20 burb.. got all excited until I noticed all the frame loss and no cross member, just custom perches to the block from each side! seller sort of inherited so they didn't know too much about it.. but I knew exactly why all the door margins were off and the driver's door wouldn't even close to latch! ![]() then the body had serious issues so I had to leave that one and drag the trailer home m/t ![]() from my understanding there weren't any BBC in the K srs because the K frames are narrower than the C frames.. so the point is, you can put anything in anything, just gonna have to fab a little bit sometimes to get it in there right.. look just under #2 plug boot, worse in other places ![]() ![]()
I started out with nothing - and I still have most of it |
#22 |
So here are some pics of motor in the bay, and the holley dominator efi that will be used to support this monster!
#23 |
LOL, I like the way you think!!!
A 632??? Why NOT, you only live once!!! |
#24 |
#25 |
