01-08-2019, 03:13 PM | #1 |
Trans and motor not listed on spid
My 71 gmc with a 307 and a 4 speed manual is not listed on the spid. Now i know the standerd trans is a 3 speed. With the 4 speed being an option. But the 4 speed looks like it is factory. So is it possible the spid is wrong? I don't think the 307 was a standered option. But I can't see any evadence saying it did not come with one besides the spid.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
01-08-2019, 03:56 PM | #2 |
Who Changed This?
Re: Trans and motor not listed on spid
If it came with a V-8 and there is no option listed, the engine will be a 307. You got me on the 4 speed, though.
01-08-2019, 04:10 PM | #3 |
Ok that makes sense. Standered v8 307 so not listed. Got it. Now on to the 4 speed
01-08-2019, 04:12 PM | #4 |
Yep, the 'factory' or stock motor would have been the 307.
The only item that would show up on the SPID would be an optional change to that...either up or down. ie: 292-6 cylinder, or 350 or 400, etc. As for the 4 speed...well there is a chance that the owner took it back to the dealership after he got it to have it (factory/dealer) upgraded to a 4 speed. The GM dealership would have easy, quick access to all the correct factory parts so it would naturally and expectedly look and perform as an original. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-08-2019, 05:00 PM | #5 | |
01-08-2019, 05:04 PM | #6 |
Or it was ordered with the 3 speed. But the guy wanted a 4 speed and as part of the deal he made them swap it over.
01-08-2019, 07:12 PM | #7 |
All about them K’s
Or somebody got a parts truck along the way and swapped it over in the driveway... hard to tell what has happened in the last 50 years. I agree it does look factory in that it’s got the correct parts column and all. I wonder if the floor has the correct reinforcements where the high hump bolts in?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-08-2019, 07:44 PM | #8 |
Very strange, 3 speed would have a low hump floor and yours looks original due to color and bolts. Your column is black which is correct for your interior color which is black.
01-08-2019, 08:34 PM | #9 |
That's what I thought. If some one did it in the drive way the did a really good job. As for the hump I'll crawl under it tomarrow and see if it is correct. And take some more pictures
01-08-2019, 08:37 PM | #10 |
A three speed would have column shifter no ?
71 C-20 07 Magnum RT AWD |
01-08-2019, 09:09 PM | #11 |
01-08-2019, 09:15 PM | #12 |
That could be true. Have to see what the bottom of the hump looks like tomarrow. If that checks out then who knows.
01-09-2019, 11:24 AM | #13 |
Here's the bottom of the hump whare it bolts in
01-09-2019, 02:43 PM | #14 |
I don't know much about all the GMC specifics, but it seems like they did their own thing more often than not, so I'm wondering if on GMC's the standard trans was the 4-speed? At least in '71-'72?
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
01-09-2019, 04:04 PM | #15 |
All about them K’s
That just made things real interesting. That looks the same as my K20 high hump floor. Sure looks like that cab was born with a high hump.
01-09-2019, 04:09 PM | #16 |
I think this comment has a lot of merit, GMC I bet is 4spd standard eq. For 72. GMC always has slightly upgraded features that differentiate it from a Chevrolet. Look for the build sheet under the seat or behind it, I have never seen one on the gas tank but have heard people say they can be found there too.
01-09-2019, 04:11 PM | #17 |
I agree that your ur cab came with a high hump floor, those plates are spot welded to the floor, Very hard to duplicate it and why would you way back then and on such a basic truck?
01-09-2019, 04:58 PM | #18 | |
01-09-2019, 05:50 PM | #19 |
Ok I found two GMCs i don't know the year but they list HD 4 speed close range. Or is that different then the normal 4 speed. Like iv seen on chevys?
01-09-2019, 06:02 PM | #20 |
Who Changed This?
"HD Close Ratio" looks more like an M22 in a car, to me. I wonder what the transmissions actually looked like in those trucks.
M38 was a 350 trans, M40 was a 400 trans in cars. Trucks used M49 for either one. Different numbers, so maybe the M28 is truck speak for car type M22. That would be pretty cool to have a rock crusher trans in a truck.
01-09-2019, 06:41 PM | #21 |
I could pull a house in 1st. I just skip it and use 2nd as 1st. But think that's how these sm465 where l. If there's even a close ratio then that then you could pull a small moon.
01-09-2019, 06:56 PM | #22 |
All about them K’s
Isnt the close ratio the np435?
01-09-2019, 07:21 PM | #23 |
Maby. I don't realy know. I'm pritty shure mine is a sm465. but I could be wrong
01-09-2019, 10:31 PM | #24 |
Yes, the HD close ratio trans is the NP435. That being an optional trans still doesn't answer the original question. Very interesting.
01-09-2019, 10:51 PM | #25 |
Ok that is ruled out then. Man I would think that some one would know. Thare most be an answer. I'm gusing it could be two things. Ether the spid has a error and don't show it. Or 71 GMCS standered transmission is the 4 speed. Second option is more likely.
