Old 01-09-2019, 10:18 AM   #1
speedygonzales
speedygonzales's Avatar
Aluminum Gen I Vortec timing cover..If you're tired of plastic
Came across this some months ago.
cast aluminum timing cover
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-09-2019, 10:49 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Aluminum Gen I Vortec timing cover..If you're tired of plastic
I looks like it is cast for a crankshaft position sensor, but it looks like it wasn't machined.
It doesn't look like it will work on stock engines.
EDIT: It says in the description: Timing Cover, 1-Piece, Aluminum, Black, Chevrolet, Small Block, Without Crank Sensor, Each
The only bad thing about the plastic ones is they aren't re-usable. The gasket is glued/bonded to the cover. But they are cheap enough that it doesn't matter. They don't have issues with leaking, and I've never seen one crack/break.
95 S_Trucker is offline   Reply With Quote
Old 01-09-2019, 10:55 AM   #3
95 S_Trucker
I did some more digging.
They do offer 2 covers that will work with crankshaft position sensors:
https://www.summitracing.com/parts/hly-21-153/overview/
https://www.summitracing.com/parts/hly-21-152/overview/
gen i, timing cover, vortec
