Old 01-15-2019, 08:56 PM   #1
dondb
Trailing arm bushing question
I removed my trailing arms had them sand blasted and hit them with 2k epoxy. After i put the epoxy on i was thinking i should not have installed the bushings with the epoxy in the shell? So....that's the question, should i remove the epoxy before inserting busing or just install it??
1969 C-10 LWB SS
1969 Camaro Pro Tour
2002 Camaro SS LE Rag Top #937
dondb is offline   Reply With Quote
Old 01-17-2019, 12:25 PM   #2
bigmac73
bigmac73's Avatar
Re: Trailing arm bushing question
I would clean them up with some fine emery cloth and grease them good before installing them
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-17-2019, 12:52 PM   #3
dondb
Do i need to go down to bare metal or just smooth out the epoxy grease and install?
Thanks for your reply
1969 C-10 LWB SS
Old 01-17-2019, 03:53 PM   #4
bigmac73
bigmac73's Avatar
well how thick in the epoxy? I am sure it will wear off over time , but if it is a rough surface you do not want it eating into your bushings, I would just take it back down to the factory set up (bare metal)
Mike
Old 01-17-2019, 04:10 PM   #5
dondb
Easy enough to do when the arms are out.....Thanks
1969 C-10 LWB SS
