Old 01-27-2019, 04:39 PM   #1
GMCNUT
GMCNUT's Avatar
Hickey Sidewinder Winch
Well, damn....I bought a Sidewinder without a Blazer / K truck mounts with it and now I am stuck. Guess I got a little ahead of myself
If any of you hear of one with all three Hickey mounts included that can be bought let me know. I will buy a second one to get the mounts since they are not something you can fab without originals in hand. Any help appreciated
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-27-2019, 04:41 PM   #2
GMCNUT
GMCNUT's Avatar
Re: Hickey Sidewinder Winch
I would add that I have a great fab shop to make several sets off anyones entrusted originals - I would pay you a large deposit and you'd ship me your three mounts, Id have them replicated for everyones benefit, and send your mounts back to reclaim my deposit.
Old 01-28-2019, 05:03 PM   #3
cleszkie
cleszkie's Avatar
I made my own mount. I did not attempt to copy the Hickey mounting plates. Mine mounts a little farther back and allows me to keep more of the front bumper intact. Much cleaner looking in my opinion. I bolted to large pieces of industrial angle iron to the frame rails (cold rolled 1/2 inch thick) and then bolted the diamond plate mounting plate to those with 9/16 grade 8 hardware. The winch simply bolts to the mounting plate with the circular bolt pattern. If I need to service the winch, I just remove the four bolts that hold the mounting plate to the angle iron and the whole thing drops down. Attached are some pics I took when I first installed it. I should note that this was over 10 years ago and the which has been used to pull other trucks out of stucks many times without any damage or distress to my mounting system.
cleszkie is offline   Reply With Quote
Old 01-31-2019, 11:05 AM   #4
GMCNUT
GMCNUT's Avatar
WOW! That is exactly what I need! So is there simply no way to avoid cutting the front bumper by lowering or sliding the winch toward the engine more, etc? That looks a little daunting to cut around just enough like that. Can you figure out a way to show where the angle brackets mount and how wide or long they are etc? better yet, what can I pay you to re-make your set just as yours is now and sell that copy to me?
Old 01-31-2019, 01:45 PM   #5
cleszkie
cleszkie's Avatar
The winch is positioned as far back towards the motor as possible. There is a cross member on the truck frame that keeps it from going any further. Yes I had to trim the bumper but you would have to do that anyways with the Hickey mount. I will take more pictures of the mounts I made to give you a better idea.
I can't really make another and send it to you because its the kind of thing that needs to be fit to your truck. Also, the metal I used is not the kind that you can pick up at your local Home Depot. I found the big angle iron and high carbon diamond plate at a local machine shop. Both were recycled scrap. I doubt I could easily find the same stuff.
I just wanted to give you an idea of how to make do without the Hickey mounts so you could do it yourself in a similar manner.
