Old 02-11-2019, 07:09 PM   #1
kipps
Recommended 3/4 ton shock absorbers?
The truck is a 1987 3/4 ton, standard cab, long bed 4x4. Oversize tires, no lift. Will be used for some limited, but heavy towing; 16 foot gooseneck cattle trailer, which will be stuffed full of either cows or a skidloader. The rest of the time it's to be a typical farm truck and personal transportation.
The engine is out of the truck; I assume it's a lot easier to replace shocks now rather than once the engine is back in. Can anyone chime in on this? How hard is it to replace front shocks on a complete truck?
Do I pick up whatever shocks are recommended by the auto parts store, or do I shop for a specific brand, type, whatever?
kipps is offline   Reply With Quote
Old 02-11-2019, 07:24 PM   #2
sweetk30
sweetk30's Avatar
Re: Recommended 3/4 ton shock absorbers?
off the shelf cheeper i go yellow monroe shocks .
best off the shelf these days bilstien shocks might have to order tho . the 5100 series .
2wd or 4wd there easy 2 bolts each . but yes faster with a engine out but not required .
if you not in a hurry www.rockauto.com for great prices .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-12-2019, 02:20 PM   #3
DieselSJ
Shocks are super easy and there is nothing that gets in the way if the engine is in or out.
Bilstein.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 02-12-2019, 06:07 PM   #4
tucsonjwt
I bought my 83 C20 with yellow Monroe shocks installed 17 years ago and they are still good - about 45K miles of use and some of it was fully loaded with dirt. I don't know if Bilsteins would give you better handling. I would be more inclined to look at Helwig helper springs with that heavy load. I would also make sure that your floating rear axle is up to the task as well as the differential. I you do need axle seals (aka wheel seals) on the rear I would make sure you get later version OEM GM 2 piece axle seals. The one piece axle seals leak.
I am guessing that 16' of cows weigh a lot, so I would think a 1 ton dually would be a better choice. Of course, I have never hauled any cows.
tucsonjwt is offline   Reply With Quote
