02-19-2019, 01:06 AM | #1 |
Holding Hubcaps
Hey Folks
How do you fasten your hubcaps to your wheels? Is it worth buying them or just making them youself? do you tack weld them to the wheels? or drill and screw/bolt them in? Pic for attentiton. Thanks, |
02-19-2019, 02:33 AM | #2 |
Re: Holding Hubcaps
well that escalated quickly. I recently put stock clip caps on a rally wheel by trimming the clip cap a little and welding a cheap rally cap to it. worked great. for your case, you have clip caps and nub wheels. you might be able to order clips to drill and screw to the center portion of the wheel and that will let the clip caps fit. do a search on ebay for VW hubcap clips, sometimes you can get 20 for under 15 bucks. then you measure, mark, spin the wheel with a marker so its a true circle, drill and attach. also, there is a guy who modifies caps and wheels, may not be cheap but his website is thewheelsmith.net
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
02-19-2019, 03:12 AM | #3 |
Re: Holding Hubcaps
It would be simpler to buy a set of the correct wheels with the clips on them.
Then you wouldn't have those nubs sticking out around the hubcap and holding it off the wheel.
02-19-2019, 07:07 AM | #4 |
Re: Holding Hubcaps
02-19-2019, 10:10 AM | #5 |
Re: Holding Hubcaps
just use duct tape. that should hold them on for the first block ….
02-19-2019, 12:04 PM | #6 | |
Re: Holding Hubcaps
but if thats what you want, wheelsmith can make them too, the wheels and the caps. keep in mind he wanted $160 ea for those gmc hubcaps to fit rally centers, probably totally worth it but I did all 4 myself for $150. I would probably get a flatter nub hubcap and weld the clip hubcap to it after trimming the back flat. it would have a shoulder you could paint the wheel color and I bet no one would notice ever.
02-19-2019, 02:11 PM | #7 |
Re: Holding Hubcaps
My bad there, I didn't even count the lugs. Yup that is a big problem. When you get old your eyes don't always tell you the whole story.
What about taking a painted 8 lug hubcap and trimming the center out and using it as an adapter for the smaller cap? Paint it to match the wheel and it shouldn't show that much.
02-23-2019, 05:47 AM | #8 |
SWB 4x4 Collector
Re: Holding Hubcaps
I think there are aftermarket clips for Volkswagens? Maybe that should work.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-23-2019, 04:02 PM | #9 |
Re: Holding Hubcaps
I bought aftermarket clips for a Chevy truck thank you very much. They may have been designed for a VW, but they were sold for the truck so that's what I'm going with.
And after they were purchased, I have never used them. Instead I found stainless baby moon caps that fit nub wheels. So i have this bag of clips taking up valuable shelf space... |
