Old 03-21-2019, 05:29 PM   #1
nadodave
Grille for a '63 panel
Hello:
I am sneaking up on having my '63 Panel roadworthy. One key items remaining is the grille. Mine is probably fixable, but really want a chrome grille and I am guessing that it would be $1000+ to redo mine. There also do not seem to be a lot of '63 grilles around. At the risk of being banished for heresy, will a '64 grill fit without much modification?
Thanks in advance
nadodave is offline   Reply With Quote
Old 03-21-2019, 06:10 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Grille for a '63 panel
PM sent...and, yes, a '64 and up grille will fit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-21-2019, 07:56 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
There was a guy on here who had his steel grille powder coated chrome. Looked amazingly similar to the Silver Anodized original finish.
Old 03-26-2019, 07:58 AM   #4
chakah
chakah's Avatar
...yes, that would be me
http://67-72chevytrucks.com/vboard/s...d.php?t=610093
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 03-27-2019, 06:01 AM   #5
aerotruk63
aerotruk63's Avatar
Thank you chakah. amazing finish.
Old 03-27-2019, 06:03 AM   #6
aerotruk63
aerotruk63's Avatar
nadodave. Save your grille for parts if it's in to bad condition. The supports come up as a sought after item.
grille
