03-28-2019, 07:53 PM | #1 |
"Tail Gate Best Seat In House"
Question about this headlight /parking hook up
7" Crystal Headlight w/ 10 Amber LED
LED has 3 Wire Hookups, White = Ground, Black = 12V+Function# 1, Red = 12V+Function # 2 Halogen has Red Green Black wires First I would run a battery test to see which wires are to be for bright beam and which ones are for low beam and then hook them to the head light switch accordingly TURN SIGNAL FEATURES: • 3-wire, dual function 12V LED turn signals 1. Turn Signal wire 2. Parking (Running) Light wire 3. Ground wire • Parking (Running) light stays on when headlight is on • Easy-to-install! • LED Turn signal has its own compartment integrated into the reflector • Clear turn signal lens integrated into headlight lens • LED bulbs are clear when off and amber when illuminated ____________________ The Amber 10 light is also a two system hook up and one is turn signals and the other is parking lights My question is this ,,if I run one of the amber light hook ups to the turn signals and the other hook up to another switch ..will it work ? if both are turned on together?
When you learn a thing a day you store up smart. Last edited by GOPAPA; 03-28-2019 at 08:03 PM. |
