Old 04-07-2019, 12:32 PM   #1
70c-10
02 Tahoe - change ball joint, now getting ABS light
I changed the lower passenger ball joint and now the ABS light is staying on.
I cleaned up the mounting surface for the sensor to make sure it is seated properly. I have cleaned the connection where it hooks into the harness, but I am still getting it.
I assume I need a new sensor. if so, here are a couple of questions
  1. Should I expect to change both front sensors?
  2. If I am getting new sensors, it almost seems like I'd be better off replacing the entire assebly .. thoughts?
  3. This is a 3rd vehicle that barely gets driven ... this next year it will probably log less than 1000 miles. Are there any budget replacement sensors or hub assemblies that you would trust?
Thanks!
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 04-07-2019, 06:10 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 02 Tahoe - change ball joint, now getting ABS light
If the wheel bearings are OK and they have less than 150,000 miles on em I'd just replace the sensor.
SKF or Timken wheel bearings are the way to go. Nothing else seems to last other than GM $$$$ parts. If the Timken box says Made in China on it get the SKF.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-11-2019, 09:28 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Make sure plug on ABS sensor is connected....
Remove positive battery cable for one minute then reattach...
Take it for a quick drive...should go out....unless its a bad sensor...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-17-2019, 05:40 AM   #4
70c-10
thanks guys. I figured out that I wasn't getting a signal from the ABS sensor.
I have access to a 2005 silverado that will likely become a parts truck (lots of rust). I pulled one frame that and after a short drive, the light is off now!
Thanks!
My Car
