Timing showing way off tab...wits end
Ok so here is my issue,I recently rebuilt my engine. Bored,rings,bearings new cam,heads etc. Other than that everything from old engine is being used. Issue is when a timing light is connected (vac advance disconnected). The timing mark shows at 12 o clock position way off tab with timing light. Also tried another light same results. I have verified tdc using a stop and by compression and the balancer mark is right on zero on tab. The engine will not run when I retard timing to get near the tab. Engine starts well and doesn’t kick back or ping and revs up nicely. Doesn’t ping under load in gear either. I can’t for the life of me figure out why this is happening, I have even locked the weights in the distributor and it ran bad under load so engine doesn’t seem to be running at an actual 38-40 degrees initial timing. Any insight would be greatly appreciated.
![]() Join Date: Mar 2005
Re: Timing showing way off tab...wits end
Couple of possible solutions.
1. you have a dial back type timing light and it is messed up. I would verify with another timing light (opps did't read your post closely enough) 2. Are you really hooked to #1 SBC cyl 1 is drivers side front of engine. 3. timing ring had shifted on your balancer
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#3 | |
So before working on the engine as you stated above, when you set the timing before the rebuild, the mark was different than what you are seeing today ??
Some SBC's are timed straight up on the timing cover.... How did you set the timing before your rebuild....what changed, timing cover ? balancer ? reused all old parts ? Anything changed ? |
Yup, trac must not have timed the engine before the rebuild. It sounds like the classic wrong balancer/timing cover combo.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
LOL !!!!! Please let us know what you find !!!! I love these trick questions and its like a treasure hunt.... its so exciting.
Did you do all the work ? so you should know what you did wrong....right ? GOOD LUCK !!! Oh I missed the comment "previous engine" which implies its not the original engine ? correct ? Heres one for ya... put ground shielding on your plug wires and make sure you get a good ground to ground the shielding to. Must be still winter in Canada.... Last edited by YoungPup1977; 05-02-2019 at 07:44 AM. |
#9 | |
Does your timing cover have a tab at 12 o'clock right under the water pump that can barely be seen ? Did you add an aftermarket timing tab on the cover at the 5 o'clock position as small blocks often have or add a different timing cover? It can appear as that the distributor is in correctly and it is on number one and TDC on the lower tab when in fact the TDC should be on the upper tab under the water pump. Balancer crank keyways determine what tab is used.
Happened to me. I put the motor together, didn't see the almost hidden tab and added an aftermarket timing tab. Had that distributor in and out several times 'till I finally figured it out.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#11 | |
I’ll post what this issue is when and if I find it. My original post has addressed every question people have asked. |
Are you using the same crank? Or maybe the cam gear (distributor end) is off index from the old 1?
Like trac209 says, he'll figure it out... Head scratcher for sure!
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
#13 |
OK, so I'm old & have a bad memory, but I've done hundreds engines & once, I had a belt timed ohc straight 4 that ran 'OK', but wasn't doing near what it should. Found that some gas station mechanic had replaced the timing belt 1 tooth off. Retarded cam timing 8° & ran, but lost power @4k instead of 6.5k (redline).
Put the belt where it SHOULD have been & it ran like a raped ape. Is it possible that your cam gear (timing chain) is off 1 tooth?
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's Last edited by Feel the 'Pane; 05-01-2019 at 10:00 PM. |
#14 |
Timing chain advanced one tooth?
Cam not ground properly? Did you degree the camshaft when you installed it? |
#15 |
![]() Join Date: Jan 2001
I've been wracking my brain since your first post. This is really a mystery. The only thing I can come up with is maybe the cam...
How is the power compared to what you expected? If the cam is off, it could still run, and the ignition timing would be off, but it should have a noticeable power loss.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#16 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Whether the cam was installed advanced or retarded, it is not going to change the ignition timing only the valve timing. Since the OP has verified #1 TDC and the the rotor is at #1, I would suspect something screwy is going on with the distributor.
#17 |
Uumm, if the OP is talking about a SBC, ignition timing is driven by the cam.
#18 |
Yes but you can adjust the distributor independent of the cam timing. Even if the cam is off a tooth, you can get the distributor where it needs to be.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#19 | |
edit: The crank pulley bolts to the center section. mark TDC on the crank pulley and see if it lines up with the balancer while running.
#20 |
What vehicle is this SBC in ? I am assuming its a SBC, no where have you indicated what engine it is..... its a Chevy correct ?
baby steps one question at a time...…. Year Make Model CID please... Last edited by YoungPup1977; 05-02-2019 at 08:13 AM. |
#21 |
Yes Sbc,look no offence intended but I’m just gonna stop replies to this thread as nobody has either taken the time to read through original post or they know zero about engines and timing.
#22 | |
By the way no offense intended in return but its really your issue and if you want help you are going about it the wrong way !! To say in this forum, read thru the OP....well where in your OP does it indicate what engine year make of vehicle.....you want us to help but wont give up information so I can help you Cant even answer my simple question year make model CID.....so we know what we are working on....the forum deserves folks like you when you state no one knows about engines and you are going to STOP replying...LOL!!! WTH, is this kids corner or something....LOL!!!!!! I wont reply any more....LOL!!!!! I don't know what your working on...most likely its a FORD !!!! You offended....LOL!!!! What a joke dude !!!! GOOD LUCK !!!! |
#23 |
I can't stop thinking about how a raped ape runs. A video would be most helpful. Lol.
#24 |
All I can say is good luck after your last post/comment.
#25 | |
"That thing ran like a: scalded dog raped ape
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's Last edited by Feel the 'Pane; 05-02-2019 at 03:21 PM. |
